- Joined
- May 21, 2009
- Threads
- 296
- Messages
- 1,381
- Location
- Paradise Calgary Alberta Canada
- Website
- forum.ih8mud.com
just wondering why you shortened the box ?
are you asking about the bed?just wondering why you shortened the box ?
yep, keep forgetting to write them to ask for some test strips to make sure it is correct.I like your new aluminum rad! Thinking about one of those myself, as my OEM one is starting to get a bit tired.
Sounds like you've beat the over heating issues you used to have. Are you still running Evans Coolant?
yes the bed, sorry just found it !are you asking about the bed?
I hope new ones where installed. I was not involved with the rebuild.Do these have valve guide seals? They are good numbers.
What is ASCD? It's a 2H so don't know.Do you have an ASCD mechanism on the side of your injection pump? Sounds like it's over injected on startup.
got the espar d5 12v. yeah, I installed it myself. the frustrating thing is I used the old one on 3 cummins dodges that I had over the past 7 yrs. so then I installed it last year on my -75 and it worked good all winter, then spring it kept failing and triggering a code, can't remember what code though, but different from what I keep getting now. So, I had the local dealer give it a overhaul over the summer and then installed it again, and kept getting a new code, so been thinking it has something to do with an obstruction, but can't find anything. So, I bought a new one and installed it and it is throwing the same fault code. Need to do a fuel delivery test.Just was going to ask if you had a coolant heater. What model espar do you have?
Did you install yourself?
