Option for a passenger side wing for trucks with no rear AC? I like the design, and actually built and all wood version just like this last summer. Unfortunately, my wife (small person) felt too close to the ceiling and I had to use it for firewood
I suspect that's going to be a common comparison. It seems like the big differentiators between those 2 are:
1) This setup is easy to remove, thereby maintaining flexbility. Once you install KISS drawers, you probably aren't taking them out.
2) The drawers provide for more organized storage, but aren't going to have as much storage space.
3) Look / style - just a matter of taste
What are some other points of differentiation?
Option for a passenger side wing for trucks with no rear AC? I like the design, and actually built and all wood version just like this last summer. Unfortunately, my wife (small person) felt too close to the ceiling and I had to use it for firewood![]()
hi there
looks great
any info on what the drawer system would look like?
thanks
Great to see more options available @suprarx7nut
For people asking for this option or that tie down... it's made of wood... you can customize it yourself. Put D-rings every 3 inches or whatever floats your boat.
When you get into customize-able heights, how low do you think it can go? I'd be interested in having it as low as possible, like 3 or 4 inches. (I removed my 2nd row seats)
Love the system you guys are building here. I already have a set of ARB drawers in the back of my truck—but I would be super interested to see some more pics and some dimensions on your sleeper extension. The potential to attach such a clean looking, finished sleep platform to the leading edge of my drawers has me pretty stoked.
Interesting question. The wing profile will change as you lower so at some point our custom fit wings would need to be altered. Aside from that though, you could go down to a few inches without much modification. We can buy smaller legs or chop some down ourselves to provide to you. I'd have to give it some more in-depth thought sitting in front of the cargo area, but I don't see why that couldn't be done.
Stand by for pics within the week. We've got the first customer build completed and will be getting some good pictures of that prior to getting it packaged up and shipped out!
Thanks! Right now the plan is to stick with the 13" platform height, which is what's driving the drawer height.
Were you thinking shorter or taller drawers?
Drawers!
We have completed the prototype and after a few days of testing we are feeling good about these drawers.
This will be available for sale very soon! As with the platform system, these will all be CNC machined for excellent precision and easy assembly. Options will be lined, unlined and sold as an individual drawer; allowing flexibility for your preferred setup/budget. These are bolt-in compatible for all platform systems.
Couple questions on this, is the bolt through the 80/20 the final design? Did you guys look into the internal fastener options they have? And are the rails standard drawer rails so you retain full extension?
The bolt through the 80/20 is the final design. Both Andy and myself use a fair amount of 80/20 in industrial applications at the day-job, and have found that the internal fasteners can move over time and would be difficult to place with the accuracy we intend to maintain with this system. With the uprights being supported under the platform with a metal backing plate/washer, we are able to create a very secure connection. Picture shows the underside of the platform, with the mounting plates/washers.
For the slides, we pretty exhaustively searched to find the exact right application. These slides are 100% full extension, which we set out as a design requirement from the beginning. This was always considered a critical feature to allow the best user experience with the drawers. We also wanted to stick to a conventional ball-bearing arrangement, as this drawer is BUTTER smooth even while fully loaded. This was another critical requirement for us. We have incorporated a closed, half-open and full open hold feature, to allow the use of the drawer in off-camber situations.
One feature we will incorporate into the production drawers is a partially nested slide. We will be able to recess the slide partially into the drawer, allowing for a larger drawer.
Curiosity question, are you guys having all the CNC work done locally in Boulder? Or did you guys look elsewhere and get bids on it to reduce cost even further?Just curious.
