What have you guys replace the cheap blue tube for the ARB with? i once had to shorten a line in the trail cause it was bended and cut and compressor couldn't keep up. it is really a pain to remove and put that inner and outer sleeve back on the tube. Have some of you went braided hose, not sure what kinf od fitting i would use, or if i would need to have to fitting pressed on the hose before install?
