Yeah I’ve never actually considered anything like this for my LC. You think I would have considering the amount of power gains you can make on an LS1 (which I have in my other 20 year old car my wife hates) with bolt ons. I’ll have to do some research.Headers (exhaust system to 3” outlet pipes), high lift cams by TODA Japan (same with the 1UZ), ported intake and exhaust heads) plus strong valve springs will definitely give you additional HP if you’re going the Naturally Aspirated route.
Is that pipe with vacuum fittings custom?Yes cobra head matched with TB opening.
You need the shortest radius 90 you can find, and that seems to be it.
People think it is just for sound reduction but it's not. Search Heimholtz. Do you think the power LT6 motor cares about intake sound reduction?Found this while reading about canister filters on the 100-series.
Why does the 100 have such a convoluted intake pipe? Is it to reduce noise while maintaining flow?
Unique Helmholtz induction feeds 2023 Corvette Z06
Unique Helmholtz induction feeds 2023 Corvette Z06www.sae.org
Yes! Ditch all that extra intake plastic. Adding to my wish list.I recently installed the airaid tundra kit. It takes 10 minutes tops. There is nothing janky about it and it fits the space between stock air box and throttle body perfectly. The directions on hose routing that come with it match up to my 98 lc. It is slightly louder, granted I have a DS exhaust manifold leak and no resonator from a recent bumper install. This kit comes with a reusable dry filter, I popped it in and it fits, old filter needed to be changed any way. Not sure if I’ll use this “reusable” filter long term. I’ll try to post a video clip a little bit later on.
You install this kit?I ordered this to try out. It's a flexible silicone intake hose that you trim to size. I'm worried it might collapse under WOT but I'm going to test that out. Might be worth it if I can make it work with the stock airbox.
I have and it's decent, no collapsing under WOT, very thick silicone, the vacuum lines supplied with the kit are pretty much useless and didn't look or seal great so I ended up making my own. Overall not a bad pipe, it's been on my truck for about 2 months now with no issues to note.You install this kit?
