You poor guy. How do you satisfy your old lady with something like that?
Edit...
There was a Gene Simmons pic here, but I hate that guy and don't want to look at him.
Your turbo can pull a lot of air (350CFM) threw your intake even if it’s restricted but that first big gulp off the stop light will take longer/more rpm to get that air resulting in later boost.
Compare it to a very dirty air filter you probably still get up to your 18 psi boost and drive fairly normally but you notice it’s a little snappier with a fresh filter.
My boost gauge also does vacuum but it’s probably not small enough increments or percise enough to repurpose. I already almost have holes in my flex pipe no big deal to poke a new hole, i should hook up my shop vacuum gauge and test this out.
What size lid outlet did Toyota give the 2LTE?
Looks like the airbox intake might be a size up on yours. Which is good.
I keep going back to the HVAC math I had to do, with static pressure. How a certain amount of drop is expected after the fan (which in this case is the engine, so it doesn't matter) but before the fan is bad.
Our system had a tiny restrictive return and was generally built by idiots (story of my house)
Furnace filters have a number on them of the drop you can expect but more than that and the problem is the return duct being undersized.
I'm tempted to try enlarging the filter housing intake, on stock 40s it has several bends and ends up even smaller up by the rad.
I don't have that pipe on either truck because it can't be helping.
I suppose with a bit of ready rod and a flat plate, one could pop the lid off the airbox but still bolt the filter in place. That'd show which side of the filter is causing it.
I have been looking for that specific lid for years. They are sold at wreckers as fast as they come in.
South Island wanted $850. Cause I had to buy the hole assembly. Look up the price new on
Toyota. Stupid. Which exact model and year is that air assembly you pictured from?
Yeah -
Air filter box c/w air intake meetering assy. (p/n - 22250-66050 - $560.70 !!! at Toyota) - clean with no rust. - $30.00
From that 11 yr old post. Can’t find them any more.
Have you done any digging on this yet?Sort of on the topic.
My air filter housing (60 series) flex pipe to smaller diameter (I haven’t measured yet) turbo is on its way out. Anyone found a suitable tapered flex pipe? Toyota part number? Or have a good used one?
