As I am now starting to add more electrical accessories to my rig I waned to install an additional Fuse Block to run them all off of. In the past I would just have tapped into an existing wire or fuse in the factory fuse block, but I have never liked doing that. A future mod I have will be dual battery set up, so in time I will run this new fuse block off of the additional battery.
I doubt I will ever fill all 14 fuses within the Block, but you never know. I went with the notion that its better to have more than you need than not enough.
So far I only have my Hella 4000 relay and my brake controller hooked up to the fuse block as of now. Short list of future additions are as follows:
CB
HAM Radio (if I ever take the test)
Satellite radio
Extra Power outlets
and anything else I can think of..
I couldn't find any room to place the fuse block on the drivers side left kick plate but I found the perfect spot for it to the upper right floorboard on the drivers side.
I was able to use heavy duty Velcro on the back to attach it to the fire wall. What is nice about that is if I need easy access to the fuse block I can simply pull it down and then put it back up.
Zane
CB
Satellite radio
Extra Power outlets
Zane
