Accelerator Cable HDJ81
Tulsa, Oklahoma
My accelerator cable is a bit sticky and I wanted to replace it after failed lubed attempts. Anyone know where I can find one or an alternative? I think the part is NLA
78150-60021
Bumping this just incase anyone has found a new alternate replacement, I check every now and then but it seems like the part is truly NLA
That part runs from cruise control to to the cable which runs to the IP and is part of a three cable system.
There is a pure cable from pedal to IP but that would bypass cruise..
Your cable to IP will end in 100 or 120.
78150-60021 is the number for LHD and 78150-60020 is for RHD, both with cruise control.
I'm on a road trip to the west coast.
Guessing the cable from an HZJ 75/79 could work.
If I was at home this could be verified.
Sticky cable? I used a motorcycle cable luber tool
Then I used carb cleaner to clean the cable
Then I used graphite spray to lube the capable and it’s never sticky since. I just lube it up every couple of years no more issue. It’s now been over 10 years it’s been great!!!
Could you verify if this cable will work? I am having trouble finding this cable for my 1990 HDJ-81 RHD 1HDT Auto with cruise control.
Also, I am interested in knowing what the 3fe Toyota part number is and if the extra length interferes with how the cable is routed from the factory?
You should have 3 cables.
One for acceleration via foot, another for the hand throttle, and last the cruise control.
My 81 is on the west coast 4000km away.
Pretty sure that in a pinch something will work if Toyota.
@Squash Thanks for the providing the part numbers but that is not what I need. I have the part numbers the issue is the only I can find for sale on line is the kickdown cable. The cable that runs from the cruiser control motor to the valve cover is stretched out past the limits of the adjusting nuts. If anyone knows of another cable that is available and fits an 1990 HDJ-81 RHD 1HDT Auto with cruise control please chime in with the part number!
It's NLA. I was able to source NOS on Yahoo Auctions Japan, but I think I got lucky. I couldn't find any references on the internet of another cable that would fit. You might be able to contact one of the salvage houses on there and see if they can get you a used one.
