ABS Light after coil spring swap
Good morning everyone. I just installed new Dobinson c59-223V coil springs on my 80 this morning. After I put it all back together I have my ABS light on. When I go 30 mph and slam the breaks it doesn't lock up, so it must be working right? My axles dropped down pretty low when I installed them. Did I stretch a wire too much, or is there a sensor that I busted. Any help would be great.
Pull the ABS codes to see which is the offending corner. Pretty straightforward to troubleshoot.
Gonna say, when you dropped your axle without disconnecting your ABS cable you stretched it and broke a wire.
been there done that !
How did you find out which one it was?
I checked the continuity of the wire
Can you pull the ABS codes with my check engine OBD2 gauge, or is that a separate tool I need?
There is a test procedure in the FSM. If i remember correctly its back to the paperclip method with a couple of extra steps
Found the test procedure. The SST is a paperclip.
Thanks for the help gentlemen. Out to the garage tomorrow morning.
