I have Method bead locks right now. Honestly not a fan. I think if I had to do it over again, I’d do KMC Enduros
I'm glad I found your build thread! Where are you planning to mount this guy?In preparation for the 1HDT, I dropped off the manifold to be drilled and tapped for an EGT probe. Luckily I had the manifold from my previous plans to turbo the 1HZ. I was Able to do this before the 1HDT got here. I’m using the Auberins round gauge in green light to kinda match the interior lights.
Looking forward to the work results! Heading to escape gears site now... I bought an SAAS 2 pod pillar mount for a boost and Egt gauge since I don't have the alt/temp pod in my dash either.There's a circa-2003 toyota radio in my radio din now. I am going to remove it and replace it with 1/8" HDPE plastic. I'll cut the holes in it. I'll be running at least one more gauge so it'll give me a good spot to keep an eye on it. I use an Escape Gear dash pad that I love so I'm not wanting to use the OEM altimeter pod but if I didnt have my dash pad, I would be using one. I use bluetooth on my phone for music straight to my amp so my radio din is useless.
BTW, I'm giving Escape Gear a ton of support for their gear. Even though its so simple as a dash pad, those extra pockets come in handy for quick storage of anything you don't want lying around.
I need to finish some rock sliders for Round Up but after that, I am going to start on the dash.
If there's anything specific yall want to see a pic of, just ask.
That one is about the perfect size of your roof! Looks great!!I have An upcoming 6 night overlanding trip planned so I finally mounted my James Baroud Evo onto the FRP top.
I used 4 Thule artificial rain gutters. I mounted Them by making a shoulder for each bolt out of aluminum tube. This would create a limit for the bolt to contract thus (hopefully) keeping the 2 layers of the FRP from being crushed. I used The provided backer plate on the inside. I used Marine sealant 5200 for the bolt holes. I used Smittybilt rain gutter mounts for this project but at6” y’all, they were still short. I used Some 1”x2” hard rubber bushings to create a 1” spacer. That gave me the lift I needed To clear the cross bars over the top. It doubles as additional cushion. I used 1x2 aluminum tubing for the crossbars. I think They’re 1/8th” thick.
I took A 10 mile drive tonight and there didn’t appear to be any issue as of now. I’ll keep my eyes on them. I wanted To get it mounted soon so I could Test it prior to the trip.
