A general suspension AHC question (1 Viewer)
Western Australia
Hi All
The old girl has been getting a little neglected (I became a victim of one Australia's venomous snakes) got some auto spark work done including a removeable power distribution box I designed on the fly. Fitted my favourite halogen spotlights FYRLYT as I find LED far too bright for country driving and the kangaroos are easier to see with halogens.
With 520k km on the clock all the AHC works with a minor weep on front shocks but as I haven't owned a Lexus before I am hoping someone could clarify a couple of points: when on corrugated gravels or very poor sealed roads the ride becomes pretty harsh (though much better than all my other LC) my BMW 740li was supremely comfortable on any surface. As I decided I will just keep fixing whatever needs repair is this a normal part of the ride with AHC or is it symptom of work being needed?
I have new genuine cans of fluid to do a change and would this help or should I look to replace the globes and or shocks?
I really like this car and after being in my brothers 2017 Nissan Patrol I love it even more as it is far superior to that vehicle.
Your thoughts and experience greatly appreciated
There are a ton of good threads on here with textbooks of valuable AHC info from the likes of @IndroCruise, @uHu, and others. I'd definitely recommend you dig through some of those to get an idea of what might need done & how you do it.
In general though, step one is measuring AHC pressures. You'll either need a very specific handheld reader, or, setup Toyota techstream (search for 'Techstream in 5 minutes) and use a cheap mini-VCI adaptor with a laptop. From there, make any adjustments to get pressures in spec (front torsion bar adjustments, rear spring spacers or replacements). YotaMD ( @suprarx7nut ) has a good video on this on his YouTube channel.
Once that is done, a graduation test *should* give you an idea of the health of the globes - but only if your pressures are set correctly.
Thanks for the reply and will try again to get the software working. Have you stuck with AHC btw?
I have - I've refurbed my system (globes, fluid, new lower and upper shock bushings, and new rear Kings KTRS springs.
Which King springs did you get? I have the KTRS-79 but it looks like they aren't in production any more
Happy with the results?
Ehhhhhh... I'm still working on it. I've got some other issues going on that affect ride quality, so I'm not sure I can blame that on AHC yet.
KTRS-79s as well - I got them used off of a fellow who eventually did a AHC delete. I was close to ordering them from overseas though!
Finally had a chance to plug in the Xtool D7 with latest Lexus upgrade and this is what it told me about the AHC
Front pressure sensor 9.4mpa and rear 7.5mpa vehicle running in park on flat ground AHC N position. Accumulator pressure sensor 10.6mpa
Could anyone shed some light on these numbers and what they mean?
Those are very high - I'd some searching in the forms for correct pressures (I don't remember them off the top of my head). The front can be easily adjust via the torsion bars, the rear may need new springs (but adjust the fronts & see what that does to your rear pressure first!).
6.9 front and 6.1 rear is ideal. You can tighten the front torsion bars to help, but for the back this indicates your springs are tired
Greetings from Brisbane ....
Here is a "Starter Pack" of documents on the AHC/TEMS systems. In summary ....
It seems likely that in a Western Australian vehicle the AHC system (and the underbody generally) is in good rust-free condition without damage to the pipelines and the wiring looms. If that is the case, then the benefits of the AHC/TEMS systems -- meaning whenever the vehicle is operating (1) auto-self-levelling in real time; (2) auto-damping and comfort adjustment responding to road and driving conditions in 16 steps in real time; (3) height adjustment by console selector when required -- all can be expected to remain functional and highly reliable for many more go-anywhere years -- provided that AHC/TEMS basic maintenance is followed, specifically:
  • annual visual inspection of underbody condition -- looking for leaks at AHC pipe joins, rusty bleeders, missing caps, leaks at ‘shock absorbers’ (which may indicate excessive AHC pressures, can be corrected easily), condition of Height Control Sensors -- two at the Front and one at the Rear -- these are longlasting 'wear items' in a hostile environment but will not last forever and eventually will breakdown, condition of bushes at ‘shock absorbers’ and at all suspension linkages,
  • annual check of Front cross-level of vehicle and adjustment if necessary using Torsion Bar adjusters,
  • annual check of vehicle hub-to-fender heights at each wheel and adjustment if necessary using the Height Control Sensor Adjusters (not the Torsion Bar adjusters) to give ~500mm Front and ~520mm Rear,
  • annual (or whenever additional permanent weight is added), check and adjustment of suspension settings if necessary (meaning Front torsion bar adjustment, packers or new springs at Rear) to ensure that AHC pressures remain at lower end of the FSM-specfied ranges for optimum damping and ride quality (per FSM at "N" height: Front: 6.4MPa to 7.4Mpa; Rear; 5.6Mpa to 6.7MPa without sub-fuel tank and total fuel of 96 litres) -- your current AHC pressures are way high, means sub-optimal damping and ride comfort, over-pressure also means risk of leaking seals in 'shock absorbers' and elsewhere in the AHC/TEMS systems,
  • annual check that the Height Control Accumulatot pressure when tested on vehicle is around 10.5MPa,
  • with heights and pressures correct, annual check of overall condition of the four 'globes' by checking that the difference in AHC Fluid Level at the AHC Tank at LO height and HI height is better than 7 graduations (replace ‘globes’) compared to 14 graduations (when ‘globes’ are new)-- note that AHC pressures tell nothing about 'globe' condition,
  • change-out of AHC Fluid Part Number 08886-01805 per Owner’s Manual each 6 years or 100,000 miles (twice as often is better for internal ‘hydraulic hygiene’) -- and use the opportunity to replace all bleeder valves AND caps (essential!) -- excellent investment for very few dollars,
  • replacement of all four ‘globes’ when approaching 7 graduations at the AHC Tank (expect 10+ years for life of OEM ‘globes’),
  • review the attached illustrated “General Description” of the AHC/TEMS systems to refresh understanding of these systems,
  • review the AHC/TEMS sections of the Factory Service Manual (FSM) at LC100 Factory Service Manual - https://lc100e.github.io/ pertaining to the AHC/TEMS systems -- same for LC100 where fitted and LX470,
Good to know that the Xtool D7 can read the AHC/TEMS Electronic Control Unit (ECU) and reveals pressure details. Does Xtool D7 also reveal relevant Diagnostic Trouble Codes (DTC's)??
Hi Guys thanks for the replies. The Xtool has been very handy with both the LX and my BMW's and as yet haven't come across anything it hasn't been able to scan and clear in a general sense and the live data feed seemed to be very comprehensive. Correctly the underbody is very clean on my vehicle as it was a highway queen for most it's life so far but in 19 years of service records I haven't seen any springs changed or torsion bar work. So if I am understanding correctly as the suspension sags the system applies more pressure to compensate? My recent experience with my 740li on the same crap roads (gravel and poor quality bitumen) was exceptionally good and the LX has seemed to get worse in the last few months on the same roads and especially the corrugated gravel. Minor weeping on one front shock absorber is the only obvious fault. A special shout out to Indrocruise from the best state in Australia to the second best state :)
You're correct in your understanding - the system is doing whatever it needs to do in order to maintain the same height. As the springs (coil springs in rear, torsion bars in front) wear, the hydraulics have to pick up the additional load.
A weeping 'shock' (really, just a hydraulic cylinder in this case) will likely correct itself once you get the pressures back into spec. It certainly should help with the ride quality too!
Once that's done, the next step is going to be doing a 'graduation test' on the reservoir which will give you an indicator of the life left in the nitrogen charged globes that actually provide the damping in the system - the nitrogen permeates through the heavy rubber membrane over decades. \
My guess is that they're probably shot & ready to be replaced, but always good to verify first.
First, kudos to @LJE who has summarised the situation accurately and succinctly.
Meanwhile, I had been tapping out the following long-winded notes in between watching TV movies -- and now that they are done, I may as well offer these notes as well ….
Wow!! 19 years and 520,000 kilometres (say 323,000 miles) is a great testament to the longevity of the AHC/TEMS system, LX470/LC100 vehicles and the “100 series” generally.
On comments and questions by @westaussielx470 …..
“minor weep on front shocks”
This is unsurprising, actually inevitable, given the very high AHC pressures now measured (Front: 9.4Mpa and Rear 7.5Mpa) and which probably have been that way for a long time. Have bars or sliders or a winch or rooftop tent or something else been added to the vehicle?? Anyway, there is a very good chance that correcting the AHC pressures will cure the leak, unless the internal seals inside the ‘shock absorbers’ really are permanently damaged. On the AHC/TEMS-equipped vehicles the so-called ‘shock absorbers’ are no more than hydraulic struts which carry a share of the vehicle mass and are used to manage the ride height of the vehicle, in conjunction with the ECU and the Height Control Sensors (two in the Front, one at the Rear). AHC/TEMS ‘shock absorbers’ have no damping function -- damping is regulated in real time by the ECU and the Damping Force Control Actuators to which the ‘globes’ are attached.
See diagrams and more information in the “AHC/TEMS General Description” document attached to my previous post #12 in this thread.
(In my own case, I learnt this by experience the hard way!! Years ago I added a steel ARB Deluxe Front Bar and ARB Intensity Driving Lights, probably not much change out of an additional 80 kilograms at the Front. THEN I unnecessarily replaced the overloaded, suddenly weeping, over-pressure Front ‘shock absorbers’ BEFORE I discovered the knowledge and wisdom available in in IH8MUD, initially from @uHu and @PADDO , then many others after that. To ‘give back’, I have tried to be a contributor since then).
In addition to internal seals suffering from over-pressure, there is another caveat concerning what should be the ‘life-of-vehicle’ lifetime of AHC/TEMS ‘shock absorbers’ alias hydraulic struts (provided not rusted out). Unlike conventional shock absorbers, these struts carry a share of the mass of the vehicle 100% of the time, even including when the vehicle is at rest! Unlike conventional shock absorbers, the AHC/TEMS units are part of the ‘vehicle support system’ and are not dampers. The consequence is that the top and bottom bushes work harder and may break up more quickly over the years than bushes on conventional shock absorbers which respond to movement forces but are not static weight-bearing. Disconnecting the units and replacing the bushes on the AHC/TEMS Front ‘shock absorbers’ is not too difficult on a DYI basis, but removing the AHC/TEMS Rear ‘shock absorbers’ to replace the upper bush can be a PITA job!
“when on corrugated gravels or very poor sealed roads the ride becomes pretty harsh”
the LX has seemed to get worse in the last few months on the same roads and especially the corrugated gravel”.
This is not how things should be. I find that ‘my’ 2006 LC100 Sahara with AHC/TEMS (now in the hands of my son-in-law in Western Australia) is MUCH better on corrugations and on rough winding trails, and in turns, and in reduction of roll, squat and dive anywhere, than my 2020 LC200 Sahara with KDSS and ARB BP-51 adjustable shock absorbers. This was tested most recently on the Plenty Highway, the Great Central Road, the Strzelecki Track, and various trails in the North Flinders Ranges and elsewhere across Australia in a Brisbane>Perth>Brisbane round trip of ~10,000 kilometres (~6,200 miles) in 2024. True -- the 19 years old LC100 would benefit from new bushes all round!
Better than stopping and fiddling with the C-spanner on the BP-51’s on an LC200, you should be able to feel by seat-of-the-pants the difference in a AHC/TEMS-equipped LC100/LX470 when using the four-position “comfort” switch on the central console. If the differences are not discernible and the ride quality is harsh, then that is telling you that either
  • stiff multi-ply Light Truck tyres at high pressures (eg BFG KO2 “E” rated or similar, at 40psi) are in use, or,
  • the AHC pressures are too high (as is now known in your case) – this impairs damping performance and system response, or,
  • some or all ‘globes’ are past their ‘use-by’ date and have lost nitrogen pressure (highly likely, almost inevitable, if the ‘globes’ are 19 years old) – this also impairs damping performance and system response, or,
  • various bushes in the linkages throughout the mechanical suspension system, Front and Rear, are past their ‘use-by’ date, or,
  • ball-joints and or wheel bearings are in need adjustment or replacement, or,
  • there is an AHC/TEMS fault which has caused the ECU to place these systems in the designed and protective “fail safe function” which prohibits variable damping by TEMS (and usually prohibits AHC operation as well). Has Xtool D7 recealed any DTC's?? There are multiple possible causes but ancient Height Control Sensors are a cause for suspicion -- and no, absence of a Height Control Sensor Diagnostic Trouble Code (DTC) on any scanner DOES NOT provide assurance that these Sensors are healthy, or,
  • some or all of the above -- and the recent change in ride quality as reported may be due to an ancient ‘globe’ finally giving up -- or it may mean that a Height Control Sensor (or its circuit) has developed a fault -- or it may mean that some other fault has developed -- such as breaks in wiring, water ingress in connectors – hopefully not!! Anyway, best to start at the top of this list with simple, basic things first, then proceed systematically.
“So if I am understanding correctly as the suspension sags the system applies more pressure to compensate?”
Yes. As the mechanical parts of the suspension age and tend to sag, or, if additional load is added to the vehicle, and also if vehicle movements cause the ride height to reduce while the vehicle is in motion in real time, then the ECU directs the AHC Pump to increase AHC pressure, causing the vehicle to rise until the voltage signal received by the ECU from the Height Control Sensors matches the correct voltage (2.25 volts) for “N” height, and the vehicle is returned to the set ride height for “N”, +/- 5mm per FSM – see new attachment. (Or 4.05 volts for “HI” height or 0.45 volts for “LO” height if either has been selected at the centre console switch. The height differences for “HI” and “LO” are permanently set in the ECU).
Note: Most scanners do not give Height Control Sensor readings in volts but instead display in inches or millimetres. At “N” height, the display in inches or millimetres should be as close to zero as possible -- FSM tolerance +/-5mm or +/-0.2inches.
If movements have caused the vehicle to become too high for the “N” height setting, then the ECU will cause the Levelling Valves in the Control Valve Assembly to open and allow AHC Fluid to flow back to the AHC Tank, and the vehicle lowers until the ECU receives the correct voltage signal for “N” height from the Height Control Sensors (ditto for “HI” or “LO” if selected).
This feedback loop and matching of voltage signals and system responses is how the Active Height Control (AHC) system works in real time to ‘actively’ maintain “N” height (if selected), all of the time the vehicle is operating (unless there is a fault condition). This is the fundamental design principle used in this auto height control system, first used in the Toyota Soarer circa 1983, before Lexus was invented. The ability to choose “LO” height or “HI” height was/is an added feature included when the system was adapted for use in the LC100/LX470 models circa 1998 (not available in all markets for LC100). The Toyota Electronic Modulated Suspension (TEMS) system -- nowadays called AVS in later models -- also emerged in 1983 as the precursor to the AHC system. Both systems have evolved alongside each other successively in LX470, LX570 and LX600.
The last few pages of the “AHC/TEMS General Description” document attached to my previous post #12 in this thread show how the hydraulic circuits actually work in these systems on LC100/LX470.
All good in theory unless the AHC system is overloaded -- which means accounting for the weight of the factory-delivered vehicle plus the weight of everything in or on the vehicle -- accessories, fittings, fuel, other fluids, persons, baggage -- everything. The FSM offers the following guidance:
The characteristics of the AHC/TEMS systems themselves are set by Toyota/Lexus and are not adjustable or reprogrammable -- or at least not by mere mortals like me! Instead, if significant permanent additional weight is to be carried, the idea at the Front is to compensate for this with additional pre-load at the Torsion Bars by winding the adjusters clockwise (as seen from below), possibly re-indexing if there is insufficient thread at the adjuster bolts, or in the extreme, by upgrading to higher spring rate torsion bars. At the Rear Coil Springs, packers sometimes are advocated but often are insufficient. A better approach is to replace the ancient OEM Rear Coil Springs with higher spring rate Australian-made King KTRS-79 Coil Springs:
In all of this it is important in Australia not to exceed the Gross Vehicle Mass (GVM) limit of 3,260kg (7,188 pounds) for LC100/LX470 (LC105 is different) so as to avoid regulatory, legal and insurance repercussions of having an overweight vehicle deemed unroadworthy and consequently illegal to use on public roads. A GVM Upgrade would need a lot of re-engineering and statutory re-certification on a AHC/TEMS-equiped vehicle and probably is not feasible.
Also attached is the Electrical Wiring Diagram for the AHC/TEMS systems -- hopefully not yet required -- but may be worth adding to the file with the documents previously supplied post #12 in this thread.
“A special shout out to Indrocruise from the best state in Australia to the second best state”.
Thank you for the acknowledgement -- just to have a ‘bet each way’, I can disclose that I was born in Derby in the Kimberley region in the North-West of Western Australia, too many years ago to reveal, now resident in Brisbane in Queensland on the East Coast!!
Some context for others:
Thanks to all for the great help. I have ordered a set of the Kings springs $205 for the pair landed at my post office and I will just chip away at the jobs but fortunately I have a mobile mechanic so if I screw it up he can come to farm. I have been running into a few people from Derby, Wyndham and the general Kimberly region but now down here in the South West. I have had 2 200 series diesels and a petrol V8 and have to say I am leaning toward the LX as my favourite and will hopefully just replace things and keep her going. I had nothing but issues with 4X4 shops when I said I want a near stock ride and keep existing ride height etc and they were always terrible as I drive on a lot of crap roads. Last straw for me was a shop that swore black and blue the Ironman Foam Cell Pros were the bomb but to their credit they offered a full refund once I sourced my own setup. Went with Outback Armour adjustables and their matching springs and wow what a difference and I actually enjoyed driving the car again. Hence my attraction to the LX and the AHC plus I do love a petrol V8.....but there is a nice 2008 LX570 down the road but my GF said she would leave me if I waste even more money on cars (she drove a petrol V8 100 at 5'0 tall for 13 years)
Once again thanks for the help and if I discover anything different I will be sure to post
I forgot to mention that most people have no idea how big Australia is and that overlay makes it clear. Many years ago my ex wife employed a young dentist from the UK who planned to drive from Bunbury WA to Melbourne for the weekend and was most disappointed when I told how long it would take. I did a stint coming back from Tasmania from Streaky Bay to Kalgoorlie in one stretch around 1500km......I slept well in Kalgoorlie
Hi All
Thanks for the great advice with the AHC. I spent 2-3 hours patiently adjusting the torsion bars with a breaker bar along with several test drives and eventually it probably dropped the front pressure a but low @ 5.8mpa (9.4 mpa) but after a 60 min gym session prior the old arms gave up the ghost. I have the rear springs on their way over and will give it all a final adjustment then. The ride was significantly improved although I have no idea how old the fluid is I will do a change at the same time. The rear also dropped to 6.3mpa from 7.5 and the system is so sensitive it senses when the 103kg is the drivers seat or not.....maybe its telling me something :D
A quick update as I finally had the Kings springs fitted and these were quite a bit heavier than the stock units and a full system flush and some tweaking of the torsion bars. With the new springs fitted it was obvious the old ones were shot and should be a big improvement with my small offroad caravan on the back but will see how it all settles down. The ride is pretty much perfect now and the system seems to respond faster and levels out quickly. Thanks for all the help and what was in effect a quick but effective lesson on AHC and I am not sure I could ever go back to normal suspension having had the 7 series BMW with electronic dampers and now the LX470 with 500k+ km it rides better than most new 4WD vehicles I have driven or owned.
