A/C front/rear evaporator cleaning
Jim_Chow
V8_Fan
Northern Virginia
I recently cleaned the front and rear evaporator on my 10 yr old LX w/ 119K mi. The A/C was still blowing cool, but didn't have that "ice cold" feel like with a new vehicle. The R134 was 1/2 lb short, but even after charging, I didn't notice a significant difference. The next step was a front and rear evaporator cleaning. I used the Toyota kit (pictured), one kit for each the front and rear evaporators. The instructions say to empty half the can up the evaporator drain tube, wait 10 minutes for it to drain, then empty the rest. Repeat for the rear evaporator. Next, run the engine w/ A/C on full w/ outside air and spray the air freshener into the intake vents. After letting it circulate for 5 min, turn off the engine and ventilate the vehicle. BTW, the drain tube is a rather fat tube that pokes out of the PS firewall (above the t-bar) and points forward. I located it by running the A/C and tracing the water drops. The rear wasn't as easy. For one, the drain tube was clogged, which made it extra tough to locate. It's behind the PS rear mudflap. Underneath, you'll see the insulated A/C tubing entering the bottom of the evap unit, which is located behind the rear right quarter panel area. From underneath, you'll see the A/C plumbing. Just behind where the tubes enter, there's a flat (black) rubber nipple with a slot in it just protruding from the bottom of the body (it's about the size of a medium to large flat-head screwdriver tip). Stick your finger into that and you'll find that inside is the drain tube. I used fencing wire to unclog mine, then followed the instructions for the cleaner. For both my front and rear evaporators, the liquid drained out pretty dirty. The results? The A/C is ice cold like in a new vehicle! In fact, it's so cold we only have to run it on low now whereas before, we had it on medium.
AC has a middle and low setting?? :confused:
There is a rear evaporator - where?
I'm trying to figure out if this is humor or not? :-)
There is a single condenser in the front of the radiator where hot compressed high pressure gas is condensed into a liquid as the temperature drops. The high pressure liquid then evaporates and cools the cabin air in one of two places (on LC's with dual climate); under the dash and PS of cargo area. Very nicely engineered system. Doesn't just duct conditioned air from the front but rather heats/cools rear air separately.
Thanks Jim - great post.
Adding it to my PM list this summer!
Not humor, maybe stupidity. I did not know this. Thanks.
Very nice! Thank you for the write up. where did you get the kits? Dealer?
Are the AC air intake vents just below the windshield by the wipers?
I ran out of the Nissan a/c cleaner (probably the same as Toyota brand)... took the cap off and used it atop a can of bathroom 'Scrubbing Bubbles', at about 1/10th the cost, and I was pleasantly surprised how well it worked. That's my plan here on out...YMMV
Supresso - can you a pic if the cap? Is it something I could 'easily' come up with? I'd love use something readily available.
TIA
I'm not sure I'd vote for anything that could leave soapy residue. That will only attract more dirt.
The Nissan two part stuff I've been using since an 80-series guy posted about it years ago is $35-$40. And up here in the land of dust its something I do at least twice per year. If I could get away with doing it every other year then I'd splurge ;). For $15 I'll check out the Toyota kit.
GreenJeans: I just saved the cap from the Nissan kit...
Used the same Toyota kit about 24 months ago and it did make a difference in the performance of the systems - it was $15 a package at the time. What's it go for now?
$24 and change at the toyota dealer....
For $24 I think I'll just head over to the dealership.
Thank you
I tried it. The air FEELS cooler, but objectively the temp of the air is the same...around 40F
Maybe my evaporator wasnt too dirty. I also washed and reinstalled the cabin air filters.
I paid about the same.
The P/N is 00289-ACRKT
