A/C and Recirc buttons not working after replacing A/C clutch bearing
Columbia, SC
So here is the back story. I bought my '99 LC from my cousin in Dallas, TX this June and we road tripped it back to Columbia, SC. Only one time did the A/C light start blinking and the A/C stopped blowing cold. We turned the climate control off and turned it back on a few minutes later and never had a problem with it the rest of the trip. Fast forward to July and I'm sitting in hot downtown Columbia traffic and it happens again. No noise, just the flashing A/C light. Once I got moving, the A/C started again.
I read on here about the serpentine belt saving feature that kicks off the A/C compressor if the pulley RPM changes. So figured something was going on, but no noises and it was so sporadic for a 20 year old car, I waited it out. About a week ago the bearing starting making a terrible noise. So I took off the clutch and pulley and pressed in a new bearing. Quiet as a mouse.
But this morning was in the high 30s when I left for work and I heard a sound coming from the right side of the dash when i turned on the defroster. Like something rubbing on the tire or like a plastic gear stripping.
Now my A/C button won't turn off and the button to switch from between recirculated and fresh air isn't working either. The blower sounds like its pushing a lot of air, but not much is coming from the vents in any position and is definitely not warm.
So my question is: Did the bearing swap mess something up in the controls or did the cold weather just expose a separate problem on a 20 year old vehicle?
Quick update. The A/C clutch is definitely engaging and disengaging. Also, the recirc/fresh air button works, just takes awhile. A/C stays lit the whole time, no matter what setting. Thoughts?
Sound from right side under dash is cabin blower motor (squirrel cage). The bearings get old and dry. Typical they quit down when warm and are fine. Not a bad Idea to pull and clean out. It's just 3 little bolt and a wire harness, then squirrel cage just drops out.
A/C button will stay lit in heat or cold settings, unless you turn is off. That button will also stick and have delayed reaction.
Found the A/C button was sticking too. Thanks for the photos and suggestion to clean out the cage. I’ll look at this weekend.
Notice the filters in the pictures. All LX470 have these and some LC do also. Any 100 series can be retrofitted for them.
There is a thread devote to this in the 100 series tech forum. These filters among other benefits, keep debris out of HVAC core.
Thanks guys. Turns out the whine is coming from the T-Case because it was cold here in SC. Gear oil was changed before I bought it, so it's still got its viscosity. Found I could change the whine pitch when I wiggled the t-case shifter knob. Funny how the noise came through via the right-hand side of the dash.
Will look at the button thread after this cold snap passes through.
