I got an email soon with the quote, and a few exchanges back and forth were made as I wanted some other bits and pieces worked on. Finally the green light was given on the rebuild, and since I was going to be out of town for a week or so, the timing could not have been better. The only downside was there would not be any pictures of the progress.
A couple of weeks later, back in town, I stopped by to check on updates. Work on the engine had stopped while they waited for new cam bearings and piston rings to come in.
New OME springs and shocks installed.
The 80 series OME springs come labeled for Driver Side (DS) and Passenger Side (PS) to level out the truck. Important to note that the PS and DS side Down Under is RHD, hence the need to not confuse yourself further.
I re-labled the springs properly using a large A4 paper taped on them, so that the ALJ tech didnt have a chance of installing them wrong.
New OEM bump-stops and manifold pipe installed.
New OEM brake lines.
Got the cracked dash top replaced with new. This thing is purdy
I was back a few weeks later, as the feedback I was getting was the engine was done but the FIP was still not back from the ALJ pump rebuilder. They had trouble properly adjusting it, which confirms our suspicions earlier that it had been tampered with by the previous owners, or possibly replaced. The pump rebuilder, who's an approved ALJ vendor struggled to get it going properly. It was getting them in all sorts of trouble. After much discussion with the head ALJ, who's done numerous 1HZ rebuilds for Coaster busses, we elected to order a brand new pump from Toyota Japan. We debated going down to the bus junkyard, but it would not have been worth it as they're a hot ticket for bus owners, and command higher than usual prices, plus once you add the cost of the rebuild, it comes close to the cost of a new pump.
The bright side; apart from a new, and reliable FIP, the new pump will come with the bolt thread for the much elusive tacho pick up sensor. I'll have an RPM gauge that will now work.
Everything done, and ready
Then off to get the new rubber mounted.
Pizza cutters getting mounted and balanced on 16" steelies
