Morning,
4:88 are amazing with 35's, i work on my kinda non stop but the last big push was right before the Rubicon in July, I stripped the axles down, regeared, did ARB air lockers and rebuilt them.
Sounds like you're on the right track and in good shape congratulations. I found mine in July 2019 for $3,000, so I know what you're saying about getting a good deal.
Yeah there's a common oil leak thread somewhere on here basically it's the front crank seal behind the pulley the oil pump seal and the distributor o-ring.
I'm planning on buying a factory Short block this year for when the time comes, I still have lots of little odds and ends to do on my 80, seems like I'm always planning on working on something.
Side note about the fan clutch even though I completely redid my cooling system I had heating problems the summer I did it, out of nowhere the brand new Aisin fan clutch blue hub failed. The fan clutch mod works, there's a threat on that too or you can just order one from Land tank, Wayyyyyy easier.
I have land tanks upper and lower rear control arms they are bulletproof and the lower ones took repeated hits over and over on the Rubicon. I installed his uppers just last week and I'll be checking my angles on my drive shaft, dominson's and sleeve both make adjustable rear control arms, if it was me I would only go with the uppers for adjustable.
Who did you go with for the carpet kit I've been thinking about interior but it's not been a priority. Was your master cylinder bad? I'm always looking at preventative maintenance items that I can just work on before things break.
I chased a bunch of vibrations from the driveline and learn quickly to just pull the drive shaft out lock the center differential in high and drive it you can quickly identify if it's a drive shaft issue. I did my u-joints that helped a lot and then I just decided to buy a brand new drive shafts, my front drive shaft I ended up getting a double carton built and I'm still having a tiny bit of vibration in between acceleration and deceleration. I talked to the driveline guy yesterday he said it was torsional vibration that I needed to start clocking the splines in the slip yoke one tooth at a time till it goes away. I dig how I'm always learning something new
