97 FJ rubber hose replacement
I'll check on those control arms....read somewhere what the pinion angle should be, will probably try to find that again to see how far out mine might be.
Could also be clock or phase on the rear shaft. I installed new U joints quite a while back but still have the slight vibration. It's not a wheel issue, because it's too fast. has to be drive shaft. It's not severe and a lot of people might not notice it. Guess it's also possible the slip yoke is worn. 250K miles might do that?
Master cylinder was preventive. One other thing. My brake pedal seems pretty soft. Ever had that problem? I'll be replacing the vacuum hoses there also when I do the water hoses. They're pretty brittle feeling also. Guess I could have a vacuum leak in a hose or bad booster.
Carpet came from StockInteriors.com Item # is 21802
Color 8655 sandstone plush cut pile
MassBack backing
$498.85 with freight in June 2020
The carpet is better than OEM, color matches OEM almost perfectly if you have the 40th anniversary taupe colored interior.
The massback backing is worth the extra $120 Probably a little harder to install, but looks to be very durable.
The molding of the carpet to match the profile of the floor is near perfect.
