- Location
- United States
Here's my pride and joy I have built up. Will try to list it all and will probably edit as I remember more things. Don't have to sell it but I will. $15K firm and no trades. It's got some bumps and dings and paint peel on drivers side. It's been used but not abused just ask anyone from J.S.C.
1995 FZJ80
175K miles
Factory lockers
OME "J" Lift front/rear with 1" front spacers
Landtank castor correction kit
ARB front winch bumper
Warn XD9000 winch
Viking synthetic line 125' 5/16"
4x4 Labs rear bumper with tire carrier, cooler carrier & bike carrier
Hanna sliders
Snorkel (the real one not the knock off)
Creeper Sleeper trans/tranny skid (rare awesome item)
Slee A/C skid plate
Slee rear locker skid plate
Custom rear control arm skids
Milford Cargo Barrier
Slee headlight harness
HIR headlights
Slee auxilary light harness with Toyota switch
Front/Rear DBA Rotors
Front Toyota 100 series pads
Longfield birfs rebuilt by Bobby @145K
Slee front driveshaft
Slee front sway bar drops
All fluids base lined when I got it @ 114K
Rotor & cap @117K
Spark plugs @ 173K
New A/C compressor and dryer @ 118K
Starter rebuilt @ 121K
Oil pump gasket & crank seal replaced @ 123K
4.88 gears installed @ 123K
Rear bearings replaced @ 123K
Fuel injectors pulled sent out and clean/calibrated @ 128K
New fuel regulator and filter @ 128K
EGR modulator @128K
PCV valve and lines replaced @ 128K
Sequoia alternator installed with Photoman bracket @ 135K
Iron Pig dual battery setup (charges main battery until full then charges both) with self jump start switch @135K
Dual yellow top Optimas (auxiliary runs winch and ham radio) with main battery installed @163K 09/02/2014
Front end rebuilt with new seals/bearings @ 145K
Valve cover gasket & spark plug seals @ 147K
New radiator installed with new coolant @ 147K
Black fan clutch with 20K/30K oil installed @ 162K
New radiator cap @ 162K
BFG KO2 315/75-16 installed @ 172K
Toyota factory dash cup holder
Toytota CDL switch
7 pin mod
Toyota factory throttle cable
Slee speedo correction box
Toyota washable air filter
Ham radio setup with antenna
CB radio setup with antenna in factory ash tray
Eclipse NAV unit
Sony speakers with Pioneer 10" sub and amp
Interior door LED's and overhead LED's
Front seats redone
Wit's End center console shallow box
Scan gauge with water temp readout
Husky liners front, second and rear
Spare factory front drive line
Spare factory birf
Spare rear control arm
Brand new in box tie rod ends from Cruiser Outfitters
2 spare factory stereos
Mot's custom second row screens for camping
Rear camping tent
Factory service manual
Factory electrical service manual
Extended breather lines for rear diff, front diff and transfer case
Extended stainless steel brake lines for the lift
PHH done with silicone kit
Replaced front window channels with factory rubber
Replaced rear hatch seal with factory rubber
Replaced air intake hose with factory
Replaced OD & D led in dash cluster
Everything works: cruise control, A/C, heat front and rear, lights, sun roof etc. No water leaks, no rust other than minor surface on sliders or bumper where the powder coating has been worn through
Have full front end rebuild kit on shelf for it (won from Beno)
All receipts and service history records
Will add some more photos if there's interest
1995 FZJ80
175K miles
Factory lockers
Warn XD9000 winch
Hanna sliders
Slee A/C skid plate
HIR headlights
Rotor & cap @117K
Spark plugs @ 173K
EGR modulator @128K
Toytota CDL switch
7 pin mod
Eclipse NAV unit
Front seats redone
Spare factory birf
Rear camping tent
