First and foremost I’ve done a ton of searching, so this post is more so to confirm my searching and thinking that, 94 locked front and rear axles will swap into my unlocked 95, given that I have the locker ECU in terms of ABS, full float/semi float, and 4 corner disc brakes.
I have a line on a 1994 donor truck with lockers front/rear, just want to make sure they’ll be able to swap over.
Any links to other threads are appreciated, I’ll keep doing some searching as well
Thank you in advance
