- Thread starter
- #21
Thanks, i just bypassed it all. After it passed the smog test, i put a BB in line before the EGR so the EGR will remain closed at all times.
Just figured that out. Thanks! I'm focusing on vacuum supply, now that the egr parts are new.I just deleted my PAIR and EGR systems and if my memory serves me correct the TVV vacuum lines route to the EVAP system. I do not believe the TVV plays any part in the EGR system.
Such an informative thread!You need vacuum at both ports off idle. I've had my front one clear, then my check engine light comes back on, and I realize it's gummed up again.
I guess the best way to clean them is when you have the throttle body off and can really get some cleaner down in there. Otherwise, you just have to go at it with a little wire.
Already had a new one relocated prior to the issue, and it tests fine. suspecting a bad check valve perhaps?That should be enough to activate the valve. You probably have a bad VSV, so check out the threads on replacing and relocating that.
Both of the 2 black/ orange vacuum check valves.... wouldn't a bad one sorta make a "vacuum leak" ?What check valve would you be talking about?
