So from some pictures I have seen it appears the '93/'94 exhaust goes through the cats (two side by side in parallel, whereas the '95-on has two, one after the other, so in series) then goes up OVER the frame rail inbetween the frame and the body, then to the muffler and out the back. Is this correct?
On the '95 and later 80-series the exhaust goes through the two cats (one after the other) then UNDER the frame and to the muffler, etc.
Is this all correct? (I have only had '95 and later Cruisers)
I'm asking because I am desprately trying to figure out how to get my exhaust OVER the frame, which is not easy to do, there is a good area for it, but after the two cats you are too far back to feed the pipe up to the good area with some clearance.
So is there anything special about the '95 and later cats? Meaning, could I put '93 cats on my '97, with some mods ofcourse, but with that setup I think I could easily run the exhaust OVER the frame.
Or, other alternative is to go with only one cat, anyone know what bad things would happen? I know Kumar runs his '96 with no cats at all, just replaced them with a straight pipe, and his does great, no check engine light or anything...so...
Any ideas..
Mark Brodis
Any ideas..
Mark Brodis
