92 fj80 shift lock solenoid
Austin, TX
I am not able to shift into reverse/N/Drive when sitting in Park unless i use the override switch. I do have the shop manual, and i checked for signals at the various wires on the shift lock ECU. I get a 12v signal when the brake is pressed from the wire designated for that. I get 12V for acc as well as ignition. The keylock solenoid seems to function as intended, can't remove key except when in Park with acc off.
The shift ECU box had some crusty black stuff on the electrical board when i disassembled it, so i am somewhat blaming that (discontinued) box 85933-60010. Intermittently the shift lock solenoid will get 12v and click back and for, like it's "trippin out" but not consistently. The signal off the shift ECU seems to be 1 or 2v when it's not working, and bumps up to 12v when it is. IS this the way that unit normally fails?
Has anyone rewired 85933-60050 that is more readily available with their existing plug to use it instead of the existing unit? Bad idea? I only have the diagram for 1992 model, any way someone could compare theirs to mine?
Attached is the plug i'm most interested in, since i saw another guy a year or 10 back who said it would not fit.
My truck is currently doing the same thing so I'll be watching to see what your fix is.
Oh, and as a follow up....if anyone has an 85933-60050 would it be possible for you to open it up and take a photo of the board? that would really help me track down if i can make it work or not....in addition to maybe comparing your service manual from a 93+ 80 series to mine and making sure all the electrical stuff "matches".
I bought a 100 series shift lock ECU, going to wire that up to use it and see what happens. I got the wiring diagram from both, and it looks like they do the exact same thing...so we shall see.
Could you post some close up pics of your damaged board, both sides if possible?
Partial voltage is an unusual failure mode but maybe we can spot some bad components that could just be replaced.
Here's the board, just for fun. I went ahead and replaced it with one out of a 2000 LC using my little home made cord.
So, as for results, it appears that this one works identically to the original. Power goes to the shiftlock solenoid under the same scenarios according to the 2000 manual i checked, as well as the Key-Lock Solenoid. The true test is obviously over time if it continues to work. The 2000 model manual says "20-28 ohms" and my 91 manual says "21-27 ohms"...that's the only difference i can see.
Hi, Have you tested those capacitors? Looks like one or more are going bad. Mike
This ended up being my issue too. After replacing brake lights and checking grounds/trailer harness it still wasn't shifting out of park. Got a used one off here from a part out and all is good now.
I had the same issue and checked lights, fuses, parasitic drain, plugs and shift lock solenoid and found nothing
In the end I pulled out the shift lock ECU from under the centre console and found the problem. The circuit board had “corroded”….
Put out the multimeter and checked all the copper tracer lines and found that 2 lines were not connected any more, so I just soldered in 2 wires to complete circuit again and now it work perfectly
I've been looking and see many different part numbers, all starting with 85933 and ending in... 60050 (mine), 60010 (above, @Mikel 80 ), Camry is 60030, etc... has anyone tried a Camry shift lock ecu? It looks identical including the wiring harnesses.
EDIT: Looks like it should work!
COMPUTER, SHIFT LOCK CONTROL​
85933-60010 - Land Cruiser/Land Cruiser Van (90-92)
85933-60021 -Land Cruiser S/T,H/T
85933-60031 -Land Cruiser S/T,H/T
85933-60050 - Land Cruiser/Land Cruiser Van (93-97)
85933-60060 - Land Cruiser Prado
85933-60070 - Land Cruiser/Land Cruiser 100 - Available new via Amayama
85933-60080 - Land Cruiser/Land Cruiser 100 - Available new via Amayama
As far as I can tell they look identical. Possibly the 100 series one has a different connector. Looks like someone has already done it (above, @hornatx) ... Shift Lock ECU - Manual Wiring Image - https://forum.ih8mud.com/threads/shift-lock-ecu-manual-wiring-image.1232021/
Shift lock diagram from a 100 series:
I ended up buying the still-in-production 100 series shift lock ECU, 85933-60080.
I can confirm the original 80 series ecu, 85933-60050, is not only the exact same physical casing, but and all the functions are the same - the cabling is just different.
However, if you pop the casing like I did, you'll notice the cabling pinout onto the board is identical! You can simply remove the cabling from your old 80 series ecu and attach it to the (still in production) 100 series ecu.
The wire colours were not the same as in the manual, either 80 or 100 series manuals, but I cross referenced the functions to pins on both EWDs, tested, confirmed works perfectly. WINNNNNNNNN!!!!!!!
