Shift Lock ECU - Manual Wiring Image
Austin, TX
Could someone possibly tell me the wiring plug pinouts for the shiftlock ECU from the FSM? I have an 80 series and i'd like to try using a 100 series shiftlock ECU to replace mine. If i had just the page where the wiring and troubleshooting steps are (with what voltage and such to expect) that would be very helpful. i have the 80 series one, but i don't want to post it in you guys' forum and muddy the waters.
I believe the toyota part number is 85933-60070
Hey there! Did you have success using a 100 series shift lock computer box?
I have the same issue... even bought a replacement 80 series one, that was ALSO broken, just in a different way. Now looking at replacing with a new one, but only the 100 series is still being produced.
I looked at the EWD for the 100 series shift lock ECU and it appears to have all the same inputs/outputs. Was the wiring harness different? I am comfortable cutting and splicing my existing 80 series connector onto a new 100 series one if it works. thanks!
EDIT: Looks like @hornatx was successful! 92 fj80 shift lock solenoid - https://forum.ih8mud.com/threads/92-fj80-shift-lock-solenoid.1231801/#post-15321701
Here is the shift lock excerpt from the 100 series manual linked above:
