Just wanted some input on what brands are good quality; Thanks!
... Has nothing to do with when the metal pieces were cast or forged, which THAT process hasn't really change all that much over the years.
... Peel apart a brand new rear axle, auto or manual transmission - take those gears out and place them next to gears from 1965 and you would be hard pressed to tell the difference.
... The chemistry of the oil is vastly improved,
... actually being absorbed the the metal rather than just coating the metal. ...
The foundry that I deal with goes on and on about the new process that they use. Claim that they can control the metallurgy, precision, etc, make much better parts than in the past. Maybe they are just blowing smoke and the industry hasn't advanced at all on 50yrs?
Using a trans as an example, will see that everything (gears, bearings, shafts, housings, etc) are smaller/lighter in newer units. The older units are more lightly loaded, the load is spread over a larger area.
You do realize all metals are porous....What brand(s) of fluid is absorbed into steel?![]()
The main advantage of synthetic is long life, if the rig isn't operated in a way that takes advantage of that, not driven often, etc, then it's a waste. If the rig is operated in a way where contamination is likely, it doesn't matter what kill me dead bouquet fluid is in it, once contaminated they are all dead and must be changed ASAP.The main advantage of synthetics are, much better ability to deal with shock loading, much better detergents and the by product of that is the fluid can be used for longer periods of time, provided a good quality filter is used.
We were on a trail run, one of the guys broke a rear axle. The owner carefully drains the fluid, we are thinking, good deal not polluting. Get it back together and he is scooping up the drained oil and attempting to put it back in, taking forever. One of the guys offers bottles of new, his reply, this is brand new, high $$ shock proof, need to save it!![]()
I guess I don't understand your point here? Should be saving it anyway, though after a failure I wouldn't run it again after a mechanical failure.
Cheap oil is cheap because has been little to no effort or advancement from the manufacturer after its initial development. I'm not saying ANY lubricant will totally protect a machine from a mechanical failure. What I'm saying is new lubricants are by far and a way better at the jobCheap fluid far exceeds the original spec,
they were designed to do.
{QUOTE="Tools R Us, post: 9907728, member: 3869"] By changing more often, gives the opportunity to better monitor condition (debris on the magnet, etc) contamination, etc, more likely to catch problems before they become huge.
I doubt many people who use cheap oil(though I'm pretty sure you do some of these things) actually cut open filter housings, really inspect oil quality, though just because you don't see obvious metal particles doesn't mean there isn't any present, or change oil more frequently. Plus if you go through hassle of changing your oil more often JUST to use cheap oil - how much money are you really saving? That aside, I have better things to do with my time changing fluids just so I run cheap oil.
We work on a bunch of Cruisers, most of them get wheeled often, and most run cheap gear oil and have never had a lubrication related failure.![]()
Do you mean "We" as in you and your friends? How can you make that claim? Just because there was oil on the parts doesn't prove anything.
I've found that the giant Cruiser gears will only last 250,000 miles when run with cheap dino oil.
Upgrading to expensive synthetics has made some of them last for a quarter million miles.
Pretty sure Mazola corn oil would also be OK for these machines. And Crisco for knuckles (It's digestible!).
