90 HZJ73 1HZ Flywheel Machining
Renosherrifs1
I'm gonna be home to put a new clutch in the my landcruiser.
Found the attached Clutch instructions that may apply and searched the FAQ?
What is the step machining required? AISIN specs out +0.5MM step.
Do I need to have the machine shop Resurface clutch contact area,
and bring down the outer thickness of the flywheel till the clutch contact area is 0.5MM less in thickness than the outside?
Thanks in advance.
