81+ Thermostat housing on 1979
pa
Hello,
I have a 9/79 with a stock 2F.
My thermostat housing has a sensor in it for the oem dash (which I’m not running).
I was looking to swap in an 81+ upper and lower thermostat hosing because it’s simpler and it looks like the bypass hose will offer better clearance for my Vintage Air brackets.
I’m running a sniper so all the temp controlled vacuum valves are removed and plugged. Just wondering if it will bolt on without any shenanigans.
Thanks,
Chris
Yep, you’ll just need the appropriate upper radiator hose to match
