80 series window belt molding
@WakoTako I sure hope so, because 75720-60021 is what I put on my '94.
75720-60021 supercedes 75720-60020.
If you look up the old part number on a site like Megazip, it will indicate that it's discontinued and list a replacement, if one exists.
That's not to say it's literally identical. Maybe they added some foam to fix a wind noise issue, changed the plastic composition, or switched suppliers. But if it's listed as a replacement, it will fit.
You the man, just got done busting the old ones off an installing these. Fit like a glove.
Thanks for the lesson too! I'll be sure to use Mega Zip next time
If I get "odd" results searching for 1994 stuff, I usually do a second search for 1995 and compare the results. It seems to help.
Just finished replacing all the belt molding and front and rear window runs. As stated above the new belt molding GREATLY reduces the wind noise as it has insulating foam underneath that on my old strips was completely gone after 30 years. Well worth the minimal trouble and time to replace.
Did your clips line up? I just tried installing mine and they aren’t lining up and I cannot move the clips.
Well that was 5 years ago but I don't recall having any issues. Any chance you are trying to put them on the wrong side or have front and rear swapped?
