80 -Series Rear Main Seal Leaking (1 Viewer)
Huntington Beach, California
1992 80 Series, had the main seal replaced because my shop said that is where the motor oil was leaking from. Had them change the main seal, leak stopped for 3 days, now it is back. Is there anything else that would cause that? Where should I look? Any ideas is greatly appreciated.
Charlotte, NC & Alexandria, VA
Often the seal wears a groove in the housing seat and replacing it with a new seal won't solve the problem. The typical solution is to seat the replacement seal deeeper in the bore, or back it up with a second seal, or both. This can also be a low cost fix if the crankshaft journal is grooved.
Used OEM Seal at Toyota dealer. Vehicle has 165K on it and looks new.
