ARCHIVE 80 Series D-Pillar Mount (5 Viewers)
Awesome, I'll stick it on with some bailing wire and velcro pushing the danger envelope to speed the R&D along... :p
Wish I had one of those fire extinguisher mounts now. :rolleyes:
I am! :p
ya what the dilly yo...
You've had the med bag now for what seems like foooooooooooorever....
Blah blah blah. I ordered up another kit from a Facebook sponsor that looked compelling.
I'm working on several projects at one time. I've been rewiring the panel on this based on the feedback given and based on the fact there were will be potentially two slots filled with wiring. Some of the specs needed to change accordingly.
It seems as though Solar will be a main focus so I've been making sure I have a solution regardless of the charge controller. Just takes time.
I'm also working on the air kits for OBA that dovetail my York OBA kits.
From an electrical perspective, it would be nice to have a 12 volt meter like the unit under the hood by the battery.
Subscribed... Oh yeah, we can help out in the first aid department too!
Flat mount or PAL/Molle mounting? What is the weight? Size?
We currently have this flat mount that can be attached to a flat surface or roll cage:
However, we just ordered supplies to fill this Molle first aid kit:
Our large kit weights approximately 8-10lbs and is 12.81 x 10.36 x 6.64
I'm rewiring my solar setup now that I've drilled a huge hoke in my roof and I need to know where you think the solar controller will integrate into your mount so I can make sure my wires reach, I'm sure they won't but regardless. Will the solar controller be high up or low and will the screw terminals be on the bottom? Mounted very low with screws on the bottom would be awesome.
The way I have it now it'll be dead center of the pillar (up/down) with the terminals pointed down. I didn't want to go too low because then it limits the types of components mounted.
