Thanks guys. I have new coolant. I'll grab a cap and look at the clutch stuff. How much is a new clutch if I need one? I might just get it.
ShottsUZJ100 said:Thanks guys. I have new coolant. I'll grab a cap and look at the clutch stuff. How much is a new clutch if I need one? I might just get it.
landtank said:I don't see where running with the thermostat partially closed automatically means the clutch is engaged and wasting energy. The clutch is controlled by the air temp that is in front of it. And if that air is cooled to the pioint where the clutch won't come on then it will have no ill effect. This is often true when driving along where ram air provides sufficient cooling.
In my specific case I was running extremely hot during weather that exceeded 85* and towing. The cooling system needed help which I gave it.
Just because my truck is running at 185* now in 70* weather doesn't mean if I removed my clutch entirely that the temp would increase.
landtank said:Extremely hot, was with a modified OEM temp gauge it was pegged over the red zone. The red zone begins at 217* and full tilt is well over 230*
Darwood said:By in the red zone do you mean top of needle touching the bottom of the red zone or bottom of needle touching the bottom line of the red zone. In the former the truck is at 212F and in the later 217F. Just making sure you are aware of this.
landtank said:The help I gave it was to advance the clutch timing as it was never locking up regardless of how hot it got.
If this whole thread was to point out that there is a parasitic loss when running a Viscous clutch you could have just stated the obvious from the begining and got no arguement from anyone I think.
SUMOTOY said:More specifically, water flow is a constant and it's placement doesn't have to favor the front cylinders in cooling. Expect to see dual water system as the next step. 100C block temps for wear and combustion, and much less in head temps to reduce detonation.
SJ
cruiserdan said:As I understand it the viscosity does not effect the temperature at which the clutch activates, it increases the ammount of "drive" at any given temperature.
SUMOTOY said:Parasitic draw from a partially closed thermostat during fan clutch lockup results in unnecessary engine draw (fuel consumption).
cary said:Actually, in BMW's case, they are varying the flow with the electric motor, allowing for full flow at low RPM and reduced flow at higher rpm lighter loads. I agree the application expansion will be a big step forward when we can control head temps much better.
landtank said:While looking at this single element I would agree, however my personal experience with my 80 has been when you run the engine over 185* your performance drops and fuel consumption increases. This was also noted by another member.
cary said:I second (third this). It seems to me that slightly thicker fluid is the way to go. By using the thicker fluid, you don't cause the clutch to engage early, potentially causing additional drag on the engine, but when it does engage, you get more airflow and more cooling.
SUMOTOY said:Could it be because your fan is now locking up causing more engine load, negating the known thermal efficiency gain?
landtank said:So according to these papers my MPG on the return trip should have taken a double hit, 1- loss in thermal efficency and 2- higher parasitic loads from the clutch.
I did record MPG both ways and saw an increase on the return trip as well as less downshifting to maintain speed.
My only thought is that the cooler engine allowed for a cooler air intake temp and a cooler head helping to avoid pre-ignition pinging. Quite a few have noticed this pinging on their trucks. Both these conditions will rob an engine of power quickly as I'm sure you know.
SUMOTOY said:A 10% gain due to lower fuel consumption at 203FF, and more gain by putting the fan engagement back to something over 203F should yield you something in the 'hood of a couple mpg, IMO.
landtank said:I'm not sure what you are missing here but the truck ran like crap when it was in that range. I've had my ass in that chair for the last 160,000 miles and this is something you can bank on.
