SUMOTOY said:Sure it will Rick, the coolant just doesn't get directed thru the radiator, there is definitely flow thru the block and head! It's just the closed loop circuit is bypassing the radiator when the thermostat is closed. Once it's open, it flows thru the radiator.
Scott Justuson
OK, but not nearly at the same rate as going through the radiator. I only want the coolant to circulate through the radiator to maintain the temp as governed by the T-Stat. This is how the truck works most of the months.
Again we are talking about Toyota's original design and what we should expect from it in a stock configuration. In my opinion we should expect a constant temp control throughout the year regardless of which month it is. I personally don't think 100* ambient temps should be considered extreme operating conditions resulting in 210* operating temps. Unfortunately I only recently realised I could scan my ECU for those readings as it would have been good to get that data this year.
For you or anyone who wants to run this truck in sub freezing weather at an elevated temp while driving around town will have to significantly alter the design. Needing to do so to achieve those results would indicate in my mind that you are working outside the design parameters of the truck.
