- Thread starter
- #61
hey man.Good advice @lazy .
One caveat about testing continuity and resistance of the wiring itself. If the wire is degraded due to age and oxidation of the copper, it may well "ohm out" OK on the multimeter, but that's essentially a no-load resistance measurement. If the wiring is degraded, it may still be not capable of delivering full voltage at the current required by the solenoid to fire correctly (which is something on the order of a few tens of amps, if I remember correctly).
Not to add to the complication, but another way to check this under load is to measure the voltage at the solenoid terminal when the key is in the start position. This is just another variation on the 16ga wire jumper test. And I'd definitely do that before swapping any components or doing other measurements. That'll at least tell you what part of the circuit to focus on.
on “Ohm out”. is there any way you could walk me through a practical example on this? i actually have a fluke MM that i scored off a pawn shop for $50. i think they thought it was busted or couldn’t sell it. and also apparently the contacts to the LED sometimes need to be cleaned so the screen can be dull. but it is like a ten minute fix AFAIK.
anyway, say in this case i would put POS probe to solenoid pos and NEG probe to ground (with the battery hooked up)? and i have it set to Ohms?
or i guess i am not testing anything there and i need to have the NEG run back to the battery terminal?
sorry i guess messes up with this for some reason. testing amps or bolts i run the NEG probe to ground because i am testing V or A? but for the Ohm test - well i could test reaistance in the whole solenoid by going neg to pos or i could test the wire /leading/ to the solenoid?
or what is the universe of electrical tests i can run here? aside from the practical test of running 16 ga from pos pole to pos on the solenoid please?
