Builds 75’ Rust O’mod to Restomod
What color are you using ? And who makes it ? Single Stage ? Sooo Nice !!
Color is a Dodge Color called Dark Ceramic Blue.
Ahhhh... that's right. I had asked you about this before - and forgot about that. Looks Soooo Good on your 40. ... Keep up your impressive (and imaginative) work on her ! ~Marc
FJ60 Power Steering is under way.
5.7 TBI. I know these somewhat newer 350’s were meant to run a little hotter due to the emissions but, my temp is staying right around 220 and maybe I’m just a little paranoid.
I’m thinking I may try a Ford Taurus fan and maybe a lower T-stat. Not sure if I have the room for a mechanical fan.
I’m just now starting to research it all.
Good luck on yours.
Good luck on yours.
I can’t do mechanical fan with my carb’d 350. At first I ran a Be Cool that slipped in the stock shroud, around town it was great, but I travel over a steep pass- I’d overheat most of the time. At my friends suggestion, I picked up a Taurus fan. As long as my timing is good, I don’t have any more issues. Shroud was pretty easy to mod, as well.
Two bits of advice my internet searching turned up:
1) get the soft start relay from a volvo(same fan according to the web). Apparently the start up draw will burn up the fan.
2) Said draw is to much for the stock ammeter and fuses, so make a separate circuit to reroute the amps it’ll pull.
