74 fj40 wheel bearing nut size
Oskaloosa Iowa
I need to change a lug stud on the front and have to buy a socket and was wanting to know the size of the nut to get the hub off? Looks like maybe 2 inch but not sure because it should be metric
Drum brake = 52mm or 2 1/16"
Just did the same thing today. Took the nut into northern tool. 2 1/8 fits best that was on the shelf. Do not by a regular socket.... Make sure you get a deep well. I speak from experience. Still had to tap nut#1 tight, nut #2, no problem...... Axle shaft gets in the way of regular socket..... Live and learn.
