I'm trying to remove the old center arm to rebuild it but i cant separate the threads on the center shaft from the center linkage arm thing. I think it's been rebuilt before considering the little slot inside the sleeve doesn't line up with the grease zerk fitting pocket. I've used a boat load of penetrant and a ball joint separator tool with a mallet. I will load up photos when I can, but is there a step I'm missing here or do I just need to keep doing this for a few more days? I also cant remove the bracket because of two rusted bolts to the frame that are just spinning in air, but maybe I could get by that if I could remove the arm.
