I recently purchased a '72 that has many mods by the previous owner. He swapped out the original steering column for a '75 I think based on the Haynes electrical schematics. The only electrical on the truck not working are the horn and the turn signals. I thin kthe horns should be no problem once I get the new relay I ordered. The turn signals however have a male 6 spade connector from the steering column. The original connector from the '72 after the fuse block is also a male spade connector if I am figuring correct? Is it easiest to just pigtail a female to female between them and figure which are the correct connections? Is there a better way?
Also, in case I decide to go further. The column now in the car has an inop ignition switch on the column. It currently uses the original switch on the left of the dash. It appears that some simple wire connections would allow a swap to the column??? Or would there be problems with that.?
