Really want to keep this hardtop, but im wondering if its repairable. Of course it is, but i guess im wondering if i can repair it. Not quite sure how Id go about it... let me know what you think. - Evan
landcrush said:I'm also going to need to find the part in between the back lift door and cap. not sure what its called? I have a picture above
I can get good gutters and fiberglass top but I need to find good sides
gozzard
fiberglass hardtop side, never rust again.
The header bar across the top has the same dimensions as a header bar from a newer Ambulance door hatch. I compared the one from my 74 to an 81 one that I had Around. One could easily modify a newer one to take the older style hinges.
Overall, your top doesnt look that bad. I repaired one in similar condition using a stick welder and some sheet metal.
That said, if you can find a mintish set for cheap, don't waste your time.
This thread may have some relivant information...
https://forum.ih8mud.com/40-55-seri...ling-81-hardtop-onto-my-74-keeping-hatch.html
Then again, I should take my own advice and junk my whole rig.
hey bikersmurf,
i am looking into a newer top with vent windows minus the amby doors. Im pretty sure you successfully kept the older lift gate and used newer sides? Was this process easy?
