ejfj60 said:the 60 is built like a tank and so far has been extremely reliable. Land Cruiser appears to be the only SUV sitting on a three quarter to one ton drive train. [... ] ...
So i guess my biggest question would be do the newer cruisers still run a heavy drivetrain. Thanks for you info.
Eric,
The 80 is also built like a tank and most would consider them extremely reliable. The 80 Series has a much more advanced drivetrain than the 60.
Specifics (related strictly to drivetrain/suspension & pros/cons for off-roading)
[/begin Beoembelishment]
1. The 80 has coil springs at all 4 corners. Most would agree this produces a superior on & off road ride.
2. The 80 (like the 60 but unlike the 100) has a solid front axle.
3. The 80 comes stock with 4.10 gears; I believe the 60 is geared higher in stock US form.
4. The 1FZ-FE engine in the 93-97 US models is a modern, 24 valve, fuel injected, high torque engine. From a purely engineering perspective, it is a far more advanced design than the prior F-series engines found in US FJ60s. For more details read the New Car Features (NCF) manual for the 96 LX450. It really is a unique and very sophisticated I6 engine.
5. The 80s are available, and most were equipped, with ABS and 4 wheel disc brakes.
6. Most 80s have full-floating rear axles.
7. Factory F&R electric lockers were an available option and a large number of the people that frequent this section on IH8MUD have selected (or retrofitted) vehicles with the locking diffs.
8. The 80 full-time 4wd is a technological marvel. It has a real, lockable, center differential, in addition to a 2-spd transfer case.
9. The 80 comes standard with 8" wide wheels; alloy or steel are available from Toyota. With no effort you can fit 33" tyres; with a little more $$ and effort you can fit 35's, and there are quite a few guys now running 37" tyres.
10. The 80 has a good auto tranny that is matched to the engine. The later models have 2nd gear start which is helpful in some off-road conditions, snow, and icy roads. Manual transmissions were not available in the US market.
11. The birfields on the 80 series are larger than the 60 series.
12. There is a proper skid plate protecting the gas tank and it has adequate recovery points.
13. The front diff on the 80 is a high-pinion diff and has reverse cut gears. This helps keep the front propeller shaft out of harm's way.
And finally, the 80 has a fully retractable antenna demonstrating that Mr T. planned for these trucks to be used off-road.
[/end Beoemblishment]
-B-
(Last sentence shamelessly stolen from someone.... I think it was Dougie.)
