gifu said:
hey brian... when you replaced your IP... did you have a shop put it in? or did you do it? i was going to have mine bench tested, but the procedure to remove it is pretty involved.
Do you have a Cummins or Onan manual?
It's actually pretty easy, but time consuming. You'll need a dial indicator guage setup to work in the back of the pump, but otherwise it's a two banana job.
Before I pull it, I'd go get a guage if you don't have one, pull the plug that goes in the back of the pump, (in the middle of the fuel lines) and get an adapter made so you can screw the dial indicator guage into the back of the pump. You'll need to be able to set it to zero.
I don't have a pump or manual handy, but basically, you put the pump on the block with the engine at or before TDC, make sure that the pump is at cylinder #1, tighten the nut on the timing gear, rotate the engine, move the pump so it's lift plunger is at the highest point, and then you tighten it up. Put the lines back in, bleed it out, start it up and go. a 17mm crows foot wrench makes tightening things up easier.
Local shop wanted $500 to take out the old one and put in the new (I called after I installed it just for s***s and giggles).
I won't be back in Cheyenne until the middle of May if you'd like to borrow my compression tester as well.
