60 LS Swap Mounts and other conversion solutions
cruisermatt
Un-manufacturable
Supporting Vendor
Winter Park, Florida
Website
www.cruisermatts.com
Hi, I've mentioned my products in a few threads but haven't ever made a standalone thread - now that a few other venders have threads in the tech section I guess I will join in. We have a few installs lined up so I figured I could get some tech notes and install pics put up in one place. I developed all these to make our in-house and DIY'ers projects easier, trying to take some of the guesswork out of the equation.
My big seller is my motor mount kit, I developed these about two years ago for 60 and 80 series and have sold around 65-70 sets so far. They use the GM truck mount designed for these engines. They are super strong and super clean. They come with the side gussets and middle tab pre-welded by yours truly. I chose not to do any sort of indexing to existing frame holes as there is some variation depending on transmission choice (For example the engine will sit a little more forwards with a Mark's adapter/H42/H55f vs. when using a 4l60 in a FJ62 and with the stock auto crossmember). They naturally line up the engine to the original 2F/3FE centerline and you just have to line up the top of the bracket with the top of the frame. Super easy.
I have them priced as inexpensively as a I can at $260/shipped and are almost always in stock or being restocked.
I also developed a whole line of wiring solutions for the common transmission swaps into both FJ60's and 62's, no more cutting splicing wires to make reverse lights work. :)
A big one that is often overlooked until the last minute is the TCC brake signal if using a GM automatic transmission. Until recently the common method was to use a cheap plastic GM brake switch and modify the 60 brake switch wiring and pedal bucket to accommodate. I decided that was pretty silly the first time I did it so now I do a simple in-line plug-in that keeps the original heavy duty metal Toyota brake switch and wiring intact.
Bump... just restocked on motor mounts and have plenty in stock.
We have a FJ62 getting a basic 6.0/4l60 conversion in the next week or two and are planning to bang it out in a very short time and will likely document the whole thing using my parts. It will look a lot like @Dubs2017 or @adman02 thread's but I would like to document it more as a complete instructional to show how easy it can be.
I am just doing an lq4 engine and 4l80e swap into a hj61 and my little brother hj60 so we have 2 engines and 2 transmissions to deal with, so I will need some stuff from you, problem is we are in trinidad and tobago w.i and parts are not easily available and I need a lot of stuff, I hope I am not breaking any rules here.
Happy to help, we can definitey ship to the islands just shoot us an email so we can get you a shipping quote.
Have fun putting the split case behind the 4l80e with aa adapter
Is there going to be a problem and if so what do you recommend?
Nothing new I would say I have a spacer I had machined to space the transfer case back more you could also use an 80 series case and the adapter for it.
Matt are these an open top? Like a bucket to hold mud and crap right against the frame?
There is a 1/2” gap at the bottom of each side for plenty of drainage.
