did you fix your seat belt problem
Hey sorry just saw your question.. Yes I was able to fix it by cleaning the belts thoroughly with one of those ebay nozzles. Took quite a bit to clean all the gunk out of the belt itself but has been working great since.did you fix your seat belt problem
Nah I couldn't take it and wasn't doing anything special so I went through and hooked it all up and got it working. Now got to go through all the settings to calibrate everything but started snowing and wanted to eat dinner. She is in there nice and tight!If you really want to get it out, try to heat it up a little bit with hairdryer. Only a little bit. Don’t melt the plastic haha.
Untitled by Greg Fisicaro, on Flickr
Untitled by Greg Fisicaro, on FlickrP0171 I believe refers to a “lean” fuel-to-air mixture in the combustion chamber. It can be as simple as fuel pump or fuel filter, since you mentioned the air mixture side (maf). You may also want to also check/service/clean the throttle body. Another area could be your coil packs and/or your injectors (either clogged) that may need refurbishing or replace with a bnew part. I would check the spark plugs last..Well Alita has thrown her first code.... thanks to the ScanGauge ii I am getting a P0171.
Have replaced the air filter
Have cleaned the MAF
Have cleaned the MAF connectors and used dielectric grease on connector
So she is still throwing the code every few hours after clearing. Tomorrow when I am at the house and have access to my tools I will pull the engine cover off to see if I have a busted vacuum line somewhere. After that, if I don't find anything FUN and easy it will be going through the process of elimination.
Yeah doing some research it seems that P0171 can be a whole lot of things. Could be Bank 2 O2 sensor, could be vacuum line, could be MAF going bad, could be air filter, could be coil pack, could be, could be, could be.....P0171 I believe refers to a “lean” fuel-to-air mixture in the combustion chamber. It can be as simple as fuel pump or fuel filter, since you mentioned the air mixture side (maf). You may also want to also check/service/clean the throttle body. Another area could be your coil packs and/or your injectors (either clogged) that may need refurbishing or replace with a bnew part. I would check the spark plugs last..
That’s bummer. Actually the p0171 is not that complicated, it’s just sooo labor-intensive. With enough time in hand I’m confident you can get this fixed. But I feel you, really can be bothersome if there’s an unwanted light there in the dash.Yeah doing some research it seems that P0171 can be a whole lot of things. Could be Bank 2 O2 sensor, could be vacuum line, could be MAF going bad, could be air filter, could be coil pack, could be, could be, could be.....
So I will start with the easy stuff, then progressively work down the line. Crappy part is that I am planning to head to southern Utah this weekend. Truck doesn't go into limp mode while driving with the code, so I will clear as necessary and not plan for anything other than freeway driving.
Right, and not having a garage or all my tools at the moment makes for things being a bit difficult to work on. Just bad timing on top of that too with the trip this weekend. Oh well.That’s bummer. Actually the p0171 is not that complicated, it’s just sooo labor-intensive. With enough time in hand I’m confident you can get this fixed. But I feel you, really can be bothersome if there’s an unwanted light there in the dash.
I once got a tank of bad gas in my Tacoma and ended up replacing the fuel filter. When I told my mechanic where I had bought gas he told me their tanks were old and he told customers not to use that station because of the problems from it. Good luck with the search.Last night I finally got a chance to play with things a bit. No apparent broken or badly aged vacuum lines that would make for a vacuum leak.
Pulled out the laptop and ran Techstream and came up with a freeze frame stating "P0171 - Fuel Trim too lean" so not sure if this means that the MAF is going out or if that is more to do with injectors or coils. No noted misfires or anything like that that I have been able to see but Techstream wasn't wanting to play nice and kept crashing on me (v13.00) when I could try to pull up the monitors.
Since I am going on a trip starting tomorrow and I will have to fill up the tank, I will throw a can of seafoam in the tank to see if possibly one of the injectors is dirty/bad. Trying to think if there was anything that happened with regards to changes and the only thing that comes to mind is that I need to change the oil (doing tonight) and I filled up at the local Costco, which I almost never do. Unless Costco got a bad batch of gas, I have never had any issues with their fuel when I have filled up there.
