5vz plugs in a 22re?
Loomis, California
Anyone ever run 5vz plugs in a 22re? I've heard they run better? I searched around but didn't find anything. Thanks!
First time I've ever heard about it. I'm curious what others have to say as well!
Not sure what they do different that matters. They have the same reach, and thread, so they fit. If I'm reading the number correctly, they are also the same heat range. The only difference I see is the hex is different.
I’m fairly certain the gap is .44 on the 5vz vs .32 for the RE. But I read in a thread that some sr5 models had .44 gapped plugs? The 5vz plugs also have the duel electrodes.
I would expect zero difference. But you could just pull your plugs see if changing the gap does anything for you.
