For Sale 5 speed Swap Kits (H55f and H150/1F)
Copperhill, TN
  1. 40 Series
  2. 45 Series
  3. 55 Series
  4. 60 Series
  5. 70 Series
  6. 80 Series
Copperhill, Tennessee 37317 United States
5 speed swap kits with pedals, clutch master and slave, clutch, bell housing, transmission and part time tcases headed out the door! If you are lookign for one......let me know!
H55F rebuilt, with rebuilt tcase, bell housing, shift linkages, shifters and knobs complete. $4000
H150/1F rebuilt, with rebuilt tcase, bell housing, shift linkages, shifters and knobs, pedals, clutch, clutch pressure plate, bearings, and flywheel complete. $6000
1986 fj60. H42 swap to an H55. It’s a direct swap on the post 85 fj60
Just need the trans and shifter.
I see you added some additional info and prices. I’m going to purchase a new trans.
Thanks for posting.
Thanks for posting.
You can get the trans only new from Toyota for about $3k
Think for information is needed. Multiple engines possible with different input shafts, changes in the H55F. Different pedal buckets for different vehicles. Those change RHD or LHD. Bell housing rotated mid eighties depending on the market. Plus were different depending on the engined. The location of the transfer case shifter does not look like split case from the 1980s. Would suggest cutting off the plastic and better description of what you actually have would help.
We build these custom per each order, so they can be any configuration. The pictures just showing a couple of orders going out the door. If you need a particular setup, let's talk and we can get it going for you!
I would like to know how much for a conversion kit for a 1hd-t with an A442F to an H151F
What else would one need for a conversion from an A440 to an H55F? How complete is this?
transmission mount?
Clutch stuff?
I’m not including the below in the question…
d shaft/s modified.
T case rebuild kit.
Carpet kit.
transmission mount?
Clutch stuff?
d shaft/s modified.
T case rebuild kit.
Carpet kit.
You don't need a tcase rebuild kit.
Rebuilt H55F 5 Speed Transmission
Rebuilt tcase
Shift linkages, shift levers and knobs
Flywheel for manual
Clutch pressure plate
Clutch disc
Throwout/guide bearings
Clutch master and slave cylinders with braided SS line
Clutch lever
Bellhousing
Clutch pedal (available but extra cost)
We don't includ dust boots, wiring or hoses if needed for the application.
1988 FJ62
A440
Crossmember? Didn’t see that, would need to source/make?
The above list for 4k
No, the tranmission without all the clutch parts, slave, master, is $4k. $5k with everything. $5.5k including the clutch pedal.
Crossmember you would need to source/make.
Just trying to clarify.
Appreciate your response.
Who does the rebuilds of the transmission and t case?
What’s the name of your company ? Do you have a link
