For Sale 5 speed Swap Kits (H55f and H150/1F)
So, if one was thinking about rebuilding a 1FZ-FE (1996-80 series with the stock auto transmission) and wanted to go with the H151...
1. is it possible to retain the stock full time transfer case (would likely rebuild just because if that helps)?
2. how much computer issues to sort out for this whole thing?
Thanks! Somewhat local to you in upper east TN.
You can keep the full time case, although not sure why you wouldn't want to go to part time. They are push button lock actuated and then you could get better fuel economy in 2wd when you don't need 4wd!
No idea on the computer. I don't deal in anything ECU based for rebuilds. But its a manual. Not sure what computer issues there would be???
Computer issues being the stock ECM or TCU that would be looking for any signal from the now missing auto transmission. There may not be much, I really don't know.
Do you offer 1FZ-FE rebuild service? PM me if needed rather than derailing your sale thread.
Thanks!
Not to hijack, but seeing that Scott doesn’t offer an ECU for the manual transmission , I have one that will be offered up soon. It’s part of a package of parts that I need to sort through.
5 speed swap kits with pedals, clutch master and slave, clutch, bell housing, transmission and part time tcases headed out the door! If you are lookign for one......let me know!
H55F rebuilt, with rebuilt tcase, bell housing, shift linkages, shifters and knobs complete. $4000
H150/1F rebuilt, with rebuilt tcase, bell housing, shift linkages, shifters and knobs, pedals, clutch, clutch pressure plate, bearings, and flywheel complete. $6000
I sent you a message on your page but im interested in a manual swap on my KZJ78 (1KZ-TE). I was looking to do an R151f currently have an A343F auto.
Let me know if thats a kit you can put together, thanks.
- Josh
- Josh
Well, that one is pretty easy! You can source it mostly yourself. Happy to help guide you! shoot me a message at: legendarytoyota4x4s@gmail.com
Need just the trans
I am looking at possibly running an H150/151 and a part time t-case (Id liketo get the 3:1 gearset) behind a healthy 2UZ (I am aiming for 350hp) in an FJ40.
I have the clutch hydraulics (pedal, clutch master/slave) for a 2F/H42 however, I am not sure if those will be compatible.
I'd be looking for the bellhousing, flywheel, clutch bits, T/O arm, transmission and transfer case.
Is this something you could at least get me into the ballpark on?
Sent you a dm
