So the other day the ball stud on the 4x4labs rear bumper swing arm snapped. Starting with knowing nothing about gas springs, eyelets, ball studs and safety clips I went into research mode.
The way the ball stud snapped tells me this is going to happen to someone else. Therefor this information will make 4x4labs rear bumper owners a much easier to get replacement parts.
This is only relevant to a specific gas springs that came with my bumper. I don't know if Luke is consistent with what he is using. But this gas springs are very good so no reason to use others.
The Normont part number is: NSE500v120AL. Here are the specs:
Normont part # NSE500V120AL
Brand Made in USA
Type Fixed Force Gas Springs
Capacity (Pounds) 120.0000
Extended Length (Decimal Inch) 15.25
Stroke (Decimal Inch) 5.0000
Rod Diameter (Decimal Inch) 0.320
Tube Diameter (Decimal Inch) 0.750
End Fitting Metal
Piston Coating Chrome-Plated
Special Item Information Item requires two Safety Clips per gas spring
Here is the sticker on the gas spring. In case your sticker is gone.
Brand Made in USA
End Fitting Metal
