When I was 18 I had a job installing loading dock equipment where I did a lot of stick welding. I never really learned how to weld properly though. It was a situation where the welder was already set to the current that we used, we only used one type of rod (didn't know what kind at the time), and pretty much everything was 3/16" mild steel. I welded a few different types of joints in a few different positions and directions which required different techniques, but my skills were rather limited.
I didn't realize that until I started this bumper. It's been a long time since I was 18. The little skill I developed is long gone, and I learned mighty quickly that different electrodes behave very differently. I now believe everything I did when I was a kid was probably with 6013, and I've used 6011, 7018, and 6013 for this project. All of my 7018 beads looked like crap, and all but the very last 6011 bead was just as bad. When I switched to 6013 everything magically turned out great! Luckily I did all of the hidden welds with the 6011 and 7018, and most of the visible welds are with 6013. I'll be grinding all the visible ones for aesthetic reasons, and nearly all of them have some awful looking welds on the other side of the joint, so I don't have concerns about the structural integrity. This is a very stout bumper.
Oh, and I had it in my head that I would have the patience to TIG weld this whole bumper, since I've had a fair amount of practice at that in the past couple of years. Granted, most of that was on stainless, and on rather small stuff around my home brewery. I did about 6 inches of TIG before I realized that it would take me weeks longer than I had planned. That was when I grabbed some stick electrodes and decided to refresh my muscle memory. Anyways, back to the bumper at hand.
With the basic shell in place, I made sure all of the mounting bolts were tight and then tacked everything.
I thought the next step was to take the bumper off and then finish weld everything. It turned out the next step was to drive to Harbor Freight and pick up a hydraulic table so that I'd be able to move forward without another set of hands. The cruiser is the only vehicle I had big enough to bring the hydraulic table home, so I drove there with the tacked-together bumper on. Luckily it's less than 2 miles down the road. Back at home I welded all the joints I could reach. If you know what you're doing, the gap at the corner of the bumper shouldn't be too hard to fill. If you're me this past weekend, it's a bit of a pain.
Then grab a beer and wait for the bumper to cool before installing it back on the vehicle to make sure it all fits, welds aren't getting in the way, and nothing deformed so much as to make reinstallation difficult or impossible. Luckily I didn't have any problems here. Remove the bumper again and we'll add the receiver, towing crossmember, receiver gussets, and recovery points. The crossmember will likely need to be cut to length. Do this, then tack in place on the top edge, somewhere that will not interfere with sliding the recovery points flush to the crossmember. You can tack the recovery points in place next. The bumper is upside-down in this photo:
Then you can slide the receiver tube in place. It will sit flush up to the towing crossmember, but because it's a bigger tube than the crossmember, you won't be welding all four sides of it because the bottom face will sit about 1/4" below the crossmember. The gussets can be tacked in place at this point. I welded mine flush with the edge of the crossmember so they're as low as possible. My thought was that will make it easier to attach safety chains when towing.
Then it's a matter of finish welding everything to this point. And in my case grinding. If you're a better welder you can probably just chip off slag and move on to the swing-out spindles. I'm halfway through grinding and cleaning up, so I'll add more once I move further.
