I thought I answered all your questions?
Good luck
Good luck
Fuel filter housing is only held on with two bolts, it should be able to be relocated fairly easy. You would need new lines, but that's it. There would still be clearance issues with the existing bracket since the throttle cable mounts to the top, but it does look like it could be clearanced. Other than that I believe you would be fine with firewall clearance. One issue I do see is that the motor might need to sit lower to clear the bellhousing and that would cause an issue driveshaft clearance. Let me know if you need pictures.Is it possible to relocated this fuel filter mount? And besides this running into the the heater valve on the firewall do you see any issues that would arise from your engine being about 3" farther back? Ignore accessorys and the factory exhaust manifold and turbo as I won't be using those.
Thanks!
Fuel filter housing is only held on with two bolts, should be able to be relocated fairly easy. You would need new lines, but that's it. Their would still be a clearance issue with the existing bracket since the throttle mounts to that, but it does look like it could be clearanced. Other than that I believe you would be fine with firewall clearance. One issue I do see is that the motor might need to sit lower to clear the bellhousing and that would cause an issue driveshaft clearance. Let me know if you need pictures.
