Took the cover off and it checked out the gasket. Gasket was in good shape and it looked to be seated on it well. I took the gasket off, cleaned everything up, reapplied gasket glue (or whatever its called) and then reinstalled the cover. I tightened the bolts down to about where they were before, based solely on my feel. I didnt want to strip the bolts and it was at a weird angle so I couldn't get a great judge of it. When I test ran it, it started to leak again from the same spot. So I tightened each of the bolts about another turn. In having it run for ~15min it wasnt leaking after the second tightening. I will continue to monitor it.
Also adjusted my idle down from ~900-950 to ~750. I may want to put it a hair up to ~800, but I will drive it this way for a bit and see how it feels.
T-bolt clamps.
The silicon isn't wrinckling but it isn't slick at all for the clamp to move over it. The hose fits snuggly over the pipe. Much of the pipe doesn't have the a lip as i needed to cut it to size. It's possible the pipe is deformed. I will check when I take it appart.
I fixed the IP leak by creating a gasket with stuff called "the right stuff". It worked well and was pretty easy. With that fixed, I can look for the other leaks. I think it's leaking around the pan. And possibly at one bolt on the timing cover. I will know more tomorrow probably.
It is possible with T bolt clamps to deform the pipe if its aluminium. I would also suggest getting beads put on your pipes, most fab shops have bead roller
I will give you a bit of advice on something I saw in one of your pictures. The oil line for the IP from the filter housing worries me a bit. The short section of rigid stock steel hose that goes to the bras fitting for the braided line, issue I see there is vibration and that rigid line getting work hardened and failing. I have seen that before multiple times when people do the same thing for turbo oil feeds. Just wanted to mention it so you can keep an eye on it.![]()
I know of a place I can go that should have a bead roller.
What would you suggest for that oil line to fix the problem? What have other done?
Problem is there is another hard line that comes off of the same spot that goes to IP gear and I didn't want to cut that line apart.
