- Thread starter
- #121
I've only seen ram's horn manifolds for the SBC. You might try looking for manifolds that fit the old school corvette 454 or BBC. I don't know if the manifolds off a 396,427, 454 are interchangeable?
The ron davis radiators are nice (I have one, but as you say they are $$).
I think you better give yourself max room between the radiator core and the waterpump...move rear of engine back against firewall best you can, so you can run the mechanical radiator fan * fan clutch combination...
I think cooling is going to be a real challenge. I know you probally could get a BB radiator off a pickup in there but it certaily would require some modificaitons, and then not sure you would be able to get air flow across the radiator properly. Do you have plans on fabbing a radiator shroud out of aluminium sheet or something?
It will a nice powerhouse if you can keep it cool. If you can run the stock exhaust that's what I would do. Seems like you would have some decent clearance with an auto trans?
Yeah I got the stock exhaust manifold to work for me so I think its gonna be alright.
Right now as it sits there is about an inche between the valve covers and the firewall, and thats about as close as I can get it I think. At that, the motor barely fits with enough room for the radiator.
I really don't think cooling is going to be that big of a challenge. I may be jinxing myself here, but The bb radiator I pulled off the truck is only 6 inches wider on each side than the stock radiator. I set it in there before I started pulling the old motor out and it looks like it is going to fit. I do however agree with you on the air flow being an issue. I have the fan shroud off the old truck also so I was just going to use that if I could get the radiator to fit. I don't really have too many options because I already have the motor as far back as I can. So if all else fails I guess its over to ron davis to pony up the big bucks. That aluminum radiator would look sick in there anyways.
