what do you think is wrong with your idle circuit solenoid? Have you checked the power and that it clicks on with switched power? Or do you think it's the o-ring? A carb rebuild kit might have the o-ring, but definitely won't do anything for you from the power point of view. What's the choke line that you are referring to? The choke is cable operated. Do you mean the vacuum hose to the throttle positioner diaphragm? If it's kinked I would replace it.
