Hi guys. Pretty technical question here. I have a 1989 FJ62 that I am slowly bringing back to life after many years of rotting away and minimal use in previous ownership. I was using it as my daily driver for about 3 months, but I broke a main leaf on the left rear corner about 2 weeks before my wedding, and in a mad effort to get the truck repaired AND lifted to clear my 33's in time for the wedding, I scored a set of aftermarket (most likely OME) heavy duty front springs from my bro in law from what was definitely a Land Cruiser front axle (removed them myself). I measured them to be approximately the same length as the front springs on my 62 so I went ahead and pulled the front end apart and then discovered that when laid side by side, unloaded, the springs that he gave me were actually a fair bit longer. I figured the shackle would just swing forward a bit, but by the time I had drilled a new hole for the center pin and got everything all lined up and bolted back into place, the shackles were pointing forward at atleast a 75* angle. Once I hit a bump in the parking lot behind the shop, they got locked forward at 90* and I knew I screwed up putting such long springs in there with no time buffer before the wedding. The rear springs I never ended up touching because I ran out of time. Anyways, I jacked it up to get the weight off it, popped the springs back to their regular position and put some wood blocks between the bumpstops and the ubolt pad to prevent the suspension from compressing far enough to lock the shackle forward.
So my problem is my spring is about 4 to 6 inches too long- I was thinking the easiest solution would be to move the front shackle hanger forward 4 to 6 inches to get the correct angle, and call her good. But then i was thinking, it might be a bad idea having the shackles that much further forward, so perhaps this would be a good time to do a shackle reversal. What do you guys think? Any further thoughts or anything that I might have missed in my pre-marital whirlwind?
