As far as i can tell, the 3F engine came about for two reasons... It brought the displacement down to 4.0 liters to avoid tax penalties on larger engines and it lowered the height of the motor to fit under the hood with the efi on top.
To do this, they had to shorten the block a lot and also shorten the rods. The stroke is not all that much shorter really...
This results in a lot of side loading on the pistons... and very short piston skirts... and a piston that drops WAY lot out of the bore in the block...
At first thought it might seem that the 3f with the lighter rotating assembly and shorter stroke will rev higher than the 2F before things go boom. Nope... the side loading on the pistons is severe and the skirts will crack at high rpm. Lower than the rpm where 2F rod bolts stretch usually. And 2f rod bolts can be replaced with stronger ones.... can't do anything about the situation in the 3F however.
The longer rod in the 2F means more torque for the same amount of power applied at the top of the piston. Longer stroke helps bring the beginning of the powerband lower in the RPM range too.
There is really nothing that the 3f has that is a gain over the 2F... it is the "E"... the EFI that produces any and all benefits that you might encounter when you compare the 2F and the 3FE. (
Things like more powerful alternators and the like really are not relevant when comapring the differences /advantages/disadvantages.
If you that the same ignition, induction fuel delivery and exhaust system as the 3FE has and hang it on a 2F... you get a better, stronger, more powerful motor. go ahead and put the cam in there that Toyota should have done as well, and raise the compression levels to suit the fuel we have available (instead of expecting it to run on Mexican ditch water the way the factory designed it to do)... And you will have a motor that will amaze those who have never seen a warmed over F series engine.
And yes it was me that said that this is the engine that Toyota SHOULD have built.
As to the TBI conversions... GM TBI on top of an OEM 2F intake will never stand up to the multiport system on the 3FE
Mark...
